TwinTurbo.NET: Nissan 300ZX forum - Two Z32 questions....using a JWT '93 TT ECU in a '91
Subject Two Z32 questions....using a JWT '93 TT ECU in a '91
Posted by w8lifter4 on August 30, 2008 at 6:28 PM
  This message has been viewed 144 times.
Message About a month ago I ended up stalling merging on a major highway. Sucked. Turns out that there was a short in the wire that turns the fuel pump on, fuse blew. Dad and I fix the short and a few misc. other things. Get in the car, turn the car on, then turn it off.....car stays running, with all that dash lights dimly lit. Search on TT.net reveals that the ECU is more than likely shot.
I have a JWT ECU from a '93 TT. Can I use this ECU in my '91 and is it ok to use it on stock boost until I can install my MBC and raise it to the recomended 12-14psi? I looked on JWT's website and the have it broken up in years like '90, '91-'92, '93-'94, etc. Didn't know if there was something special between the years that would cause a problem when I install it.
